All posts related to V3
By antonioloprete
#380100
hello,
i'm trying to use a real glass material in my architectural glass panels, but it's very hard to obtain a good result. i would like to obtain the similar result of the AGS (transparency and reflections) with a double 3d solid panel (4 mm glass + 9 mm air + 4 mm glass) but i have problem to obtain a realistic result (bigger problem to obtain a good transparency using 1.51 Nd).
do you have any suggestion?
thank you,
roy
p.s. could be nice to share real glass materials to use instead of AGS in architectural projects.
By antonioloprete
#380105
hi eric,
you're right! my problem is solved using the "hide from gi" because without this the sun make a shadow over the glass panel . thanks a lot for your suggestion.
why do you think maxwell (that is so precise on the calculation of the gi) have this problem to correct renders a glass panel with sun shadows?
By eric nixon
#380107
I think, the problem will be solved in the future, but I dont know when. This is why I excercise regularly, so that I might live long enough to see the day. :wink: Guess it must be a really tough problem to solve... or maybe its just a spanish manyana thing, :wink:
By numerobis
#380108
eric nixon wrote:I think, the problem will be solved in the future, but I dont know when.
maybe 2020? looking at the evolution of the last 10 years and when the problem solving RS2 engine had been mentioned for the first time...
