By Burkhard
#59463
I noticed there are many components from formfonts ( and others) which are not adapted to render in Maxwell. -Render failed.
Is it with modelling the objekts, texture/color placements or do i somthing wrong? ( to edit? )
Any response?
Burkhard
By RedRaven
#59464
its probably the tecture file not being found. I've had that problem which seems as though eiether the plugin cant find the files properlly or the full file path isn't recorded when you save. Only way is to find which textures they are and reassign the file in edit window.
pavol - could this be something to with virtual file paths not being read correctly during the export?
By pelias
#59564
Textures files not found might indeed be causing this. In terms of solutions there are 2 things which will be done:
- exporter has to ignore texture files which cannot be located
- better mechanism to handle texture search paths might be needed (I will think about this some more).
Pavol
