By bakbek
#49187
The idea with this plug-in you work on the model in sketchup, take care of all the things... then export to render in Maxwell - with no more work needed. well... thats the idea, the plug-in is still alpha, but it works well so far.
By pelias
#49615
fatNjazzy wrote:hi ronen thanks,
so where do i take care about texture maps such as Bump, Reflection.
what about artificial and natural light, i understand that i supouse to do it in maxwell render. am i right?
thanks alot
At the moment only texture maps are supported by Maxwell exporter for SketchUp - more will be added later on. However all special Maxwell parameters (surface finishes, emitters, camera parameters,...) can be set using MaxwellExport Ruby plugin which is part of the exporter package.
Pavol
