By ajlynn
#46315
I've been trying to use this plugin and I think I'm doing this correctly by the instructions, but every time I run it I get:
[Error]: writeMXS on There is Objects without material
Anybody know what does this? Don't all my objects have materials, even if I missed something and it just has material "Default" (I tried defining a [Default] material in my 3ds2mxs.ini but to no avail.) There are no extraneous objects, I cleaned it all up...
By ajlynn
#46337
I thought I had this figured out, that it was the earth plane which defaults to a material called BackColor that was undefined, and when I went and defined it I didn't have that error any more but 3DS2MXS gave me a much more normal crash with a Windows error box. Tried exploding everything (thanks for the tip hrothgar) and then flipping all the purple, but still no luck.
This is a somewhat complex scene - I got it to work using a very simple scene - so, is there a limit on how much geometry I can have in my 3DS file?
By yasuka
#46730
Please set not BackColor but other material to the the earth plane.
and
"Generate cameras" is checked when export.
If it is unrelated, I'm sorry.
I'm poor in English...
