All posts related to V3
By pipcleo
#391934
Suddenly having an issue with the visibility of instances in studio.....
They seem to disappear as i move round the viewport randomly appearing and disappearing when zooming in and out , orbiting etc
They generally appear (in plan) when I zoom right out and start to disappear as I zoom in.
Never had this issue before
Happens in 3.1 and 3.2 on mac with latest OS
Any possible cause come to mind ?
By choo-chee
#391945
weird...however I'm not a studio user (but Maya) so my other advice (as I use stuff made in ivy generator too...) is to create MXS refernces, it's way better to keep a full library of MXS.
's
By pipcleo
#391957
thats about 1gb of ivy right there.....
prob about 50 gb worth on this building so instancing is a far better way
anyway thanks choo-chee.....
referencing will require an awful lot of referenced objects
Strange thing is that ONLY the instances drop out
By choo-chee
#391965
in maya you can duplicate the MXS references as instances, so it's way better. you save the size of the ivy since it's stored in separate files and not the scene itself, and then duplicate all the different types as instances. i have about 10 "typical" ivy models, all are MXS, and i instance them in the scene.
By pipcleo
#391988
ok I will have to go back and try this...at least to see if these are visible
The other prob is the references only show as 'dots' which is not ideal if accurate positioning is required
