All posts related to V3
By shoeswith
#389720
Different computer and problem from last post a Faculty member is trying to install Maxwell on a home computer. Maxwell render component is crashing (not studio but the render part) if you open the render component directly it always crashes.
Sometimes a warning message comes up immediately when studio is started "Maxwell (v120-intel) has stopped working" and then studio will start. Sometimes studio will start without this warning message. Main problem seems to be the Maxwell render component.
In Studio you can sometimes get fire to start if you lower the cpu threads to 1 or 2 (it works for a bit then crashes). But it always crashes if you click on the render button (however many cpu threads you set it to and if you render material previews within studio it will also crash. You can open geometry from the library with no problems.
The computer
Processor AMD Athlon(tm) II X2 245 Processor, 2900 Mhz, 2 Core(s),
4gb Ram
Win 7 Home premium Version 6.1.7601 Service Pack 1 Build 7601 X86
Geforce 8400 GS (latest drivers downloaded)
Problem signature:
Problem Event Name: APPCRASH
Application Name: maxwell.exe
Application Version: 3.2.0.0
Application Timestamp: 560d0fd7
Fault Module Name: maxwell.exe
Fault Module Version: 3.2.0.0
Fault Module Timestamp: 560d0fd7
Exception Code: c0000005
Exception Offset: 000c944d
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 2057
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Problem signature:
Application Name: studio.exe
Application Timestamp: 560d1003
Fault Module Name: mxcommon_32.dll
Fault Module Timestamp: 560d0fbb
Exception Offset: 00236963
Locale ID: 2057
By shoeswith
#389750
Well the support guy got back to me and maxwell said their 32 bit version doesn't work. I know 64 is the way to go but one of the draws of maxwell is that it works on older computers which is another added bonus for education which often relies on older computers. Really they shouldn't advertise a 32 bit version if it doesnt work.
Does anyone know if there was a version 3.0 or 3.1 in 32 bit that worked or have you got 3.2 in 32 bit working.
