All posts related to V3
By feynman
#387354
Sometimes, but not always (which is why this is puzzling), I import an object and apply a real-scale material to it.
I am prompted to have the object's projector changed (it actually does not change - one has to click "Normalise" manually, but that's a different issue). After clicking on "Yes to all", I see that suddenly the x, y and/or z coordinates of the object have changed! Clicking the "Reset" button sometimes but not always(!) displaces the object. This is most annoying, not very helpful when positioning and re-positioning objects!
Any ideas?
Is there a simple scene you can send to tech support where this is repeatable? Otherwise it's going to be a bit difficult to find what's wrong, especially if you say it happens only sometimes.
Btw, the UVs can't be changed unless the UV type is set to other than Locked. So if they are locked, Studio won't change your objects UVs.
