All posts related to V3
By Q2
#385966
Hi all, am trying to render my objects like the picture below, so the wireframe/mesh is visible.
I tried with the procedural wireframe texture but that didn't work out the way I need it, maybe my settings are still wrong.
Maybe you guys have an simpler solution?
Cheers
Q2
By seghier
#385969
i tried with simple object
and one material with two layers
coplanar edge width = 0
the problem that we can not mask part of wieframe because it already used as mask
if maxwell allow to add more masks in one layer it will be excellent
but for better result we use photoshop with two renders
https://www.dropbox.com/s/f19p46okfmvse ... t.rar?dl=0
By choo-chee
#386048
seghier for some reason I have problem with installing the v3 demo and was wandering if you can post a screenie of the material properties, I'll try to replicate in V2... thanks
By seghier
#386051
choo-chee wrote:seghier for some reason I have problem with installing the v3 demo and was wandering if you can post a screenie of the material properties, I'll try to replicate in V2... thanks
you can not
in v3 you must use procedural textures : wireframe
v2 don't support procedural textures
