- Mon Jul 07, 2014 9:15 am
#381800
I've had a problem pop up recently that I can't figure out. I'm rendering some images via network that are 5000px. I set the SL to 14, let run and every single time I get an error at merge time that says I might not have permissions to the hdd and the merge will fail. If I render the exact same image but set the incremental SL setting so it will merge at 10,14, everything merges fine. Any ideas what is causing this problem?
- By Mark Bell
