- Mon Jun 02, 2014 7:50 pm
#380827
Please help me with this.
Sorry, I have a lot of questions about Maxwell Render. It seems like every time I use the software I get these errors that I don't know what to do with or how to fix them. It seems like there is a workflow that has to happen with MR to get everything to work properly, and I can't find the answers anywhere.
I am using Maya to handle most of my scenes.
1) When I perform a Pack and Go and a scene export. Does MR like to have all of those files in the same folder to work right or can things be in sub folders. In they can be in folders how does MR like things set up? The reason I ask is because I get errors then I try to put the dependencies in their own folder.
2) Where is the optimal location for my render files?
3) If I try to set my image and .mxi paths to a different folder then the file that contains my mxs and dependencies I get errors. Do I have to render to that folder or are their other place I need to render too?
4) I set up my render files in the Network Job Manager. I set my Progressive rendering to 2,4,8,10,12,14,18. I didn't render a .mxi. Maxwell rendered everything at SL 2 then when it went back to frame 1 it stopped and said it couldn't write .MXI output. Do you have to to render .MXI files to do Progressive rendering????????
5) I am using the network Monitor, Manager and render node to render my animation on 1 computer. Why do I get a error that my files do not have a Network Path? How do I fix this, or do I even need to worry about this error?
6) I MR does not finish a job, but it stops because of an error, MR will not let me remove that job and start over. I seems like I have to shut down my Manager, Monitor and nodes then restart everything. Why is this?
7) If I have to restart MR because of a failed render to I need to Purge the Temp files?
After MR finishes a frame, it moves the files from a temp folder to the destination folder. When this happens, I sometimes get this weird error that the .mxi file cannot be moved. What is going on and how do I prevent this in the future????????????
The more help I get on this the better. Thanks.
- By Mark Bell
