All posts related to V3
By choo-chee
#380030
hi all, this is a question for pro users... many of the images I render (I use v.2 but I don't think it matters here) lack some sharpness.
However trying to use "sharpen" in Photoshop causes some noise to be more obvious.
Is there a good workflow/plugin to get good, crisp contours without having the noise pop back into the image ...?
By choo-chee
#380095
hatts wrote:Are you using too-shallow DOF? Are you not letting the image render long enough?
I never have a problem with images not being "sharp" enough. Can you post examples?
When you compare images from other render engines, the contours of wall (I'm speaking interiors now...) are very clear and crisp.
Maxwell's are a bit vague.
Anyway I've found a good editorial about using PS high-pass and it does the trick quite good.
By devista
#380096
Can you post it?
thxs
saludos
luis
