- Wed Mar 12, 2014 2:54 am
#378690
I open an old scene.
I hit FIRE.
Modal window opens with "Data preprocess failed. Render cannot continue. Check Studio console for details".
Reason is that now the textures used therein are on a different drive than a year ago.
So I click Edit.
Modal window opens with "The following texture could not be found: K:\Texture images\texture-noise.tif Used in material: lacquer-aged-eggshell. Do you want to find a replacement?" where K no longer exists.
I click Yes.
I navigate to the new texture location on a network drive.
The Maxwell Material Editor opens.
I click UPDATE.
The material preview renders, now that it knows the new texture location.
I save the material.
I hit FIRE.
I click Edit.
Modal window opens with "The following texture could not be found: K:\Texture images\texture-noise.tif Used in material: lacquer-aged-eggshell. Do you want to find a replacement?" but I just pointed the MXM to where the textures are now and saved?!
What am I doing wrong?
I hit FIRE.
So I click Edit.
I click Yes.
I click UPDATE.
I hit FIRE.
I click Edit.
- By Mark Bell
