By Asmithey
#320118
So since I can not get my files to render successfully over the network. I though I would just render the image with Maxwell render separately on both machines with a different cpu id. I have done this in the past with 1.7. I have installed all the licensing info correctly on both machines. But the machine I started up secondly ran for awhile then gave me a message that I do not have enough licenses and it stopped the rendering. I have one standard and one node license.
Help please,
Dead line is here.
thank you,
Aaron
By Asmithey
#320130
Thank you Fernando.
Aaron
By dmeyer
#320135
You can specify both CPU ID and "-node" flag if you run it via CLI.
