#281649
Hi, I am having some succes to use displacement mappings for bricks in an architectural facade.
Looks nice but as soon as I have a wall with a hole in it or a shaped wall other than just a straight wall I get deformed surfaces showing triagulated deformed surfaces.
Anyone any help, maybe something to do with mirrored surfaces or surface being part of components ?
Francois
By fv
#281665
for now I solved the problem by adding lines in surfaces in Sketchup. Those surfaces with holes in them I devided into surfaces with 4 lines only.
Rendering takes very long though, maybe I can adjust some parameters in the material settings. The results loom very pleasing for brickwork with displacement.
If I rotate a texture in SU it seems the displacement gets deeper. Need to do some more experiments though.
