By rusteberg
#235075
i am recieving this when trying to use maxwell plugin for sketchup:
Error Loading File MaxwellExport.rb
undefined superclass `WebDialog'
i am trying to use the plugin for SketchupPro 5(the latest plugin). when installing, it insists on installing for SketchupPro 6 and points to C:/Program Files/Google/Google Sketchup 6 instead of C:/Program Files/@LastSoftware/Sketchup 5
what i dont understand, is that i've already installed the plugin on one machine here in the office, and it worked out just fine through SKU 5.
I have only Sketchup 5 installed on machine now installing the plugin through Maxwell Executable Sketchup Plugin
everything is being written to respective plugins folder, but just not working. Why is it not able to read MaxwellExport.rb? Is there a language problem between this file and sketchup 5?
Any help with the situation would be appreciated.
-Tom Rusteberg
By pelias
#236527
If you install the latest version of the plugin on Windows (ver1.8b) you get a dialog (it is a second screen) where you can choose between SU5 and SU6 installation (SU6 is a default). Do you get that? Make sure that you select SU5 in the dialog. If this fails (and you still get SU6 version installed) please send me your email address via PM. I will send you the correct version of MaxwellExport.rb (for SU5) directly while I will work on figuring out what went wrong with the installation.
Pavol
