Here are two small bubble simulation attempts, just for fun.
Static Bubble (click image to download)
Rendered @ 300 x 300 up to SL15 in 14 min per frame on Pentium D820 (50 frames total)
Chaotic Heavy Bubble (click image to download)
Rendered @ 256 x 256 up to SL14 in 9 min per frame on Pentium4 2.8HT (50 frames total)
Bubble on the Street(click image to download)
Rendered @ 512 x 512 up to SL14 in 35 min per frame on Pentium4 2.8HT (50 frames total)
Below is the material I've used for the bubble.
http://mxmgallery.maxwellrender.com/sea ... ble&id=555
For turbulance simulation in chaotic bubble, I scrolled thicknessmap texture UV.
The animations require latest version of Quicktime player.
Don't forget to loop the animations while viewing ;)
Cheers,
Tom
That's the best rendered bubble I have ever seen :shock:
By beppeg
#191676
:shock: hypnotic :shock:
By aitraaz
#191678
great job! Image
#191682
Cool. 8)
Tom wrote:For turbulance simulation in chaotic bubble, I scrolled thicknessmap texture UV.
...again with the physically-correct-ness, eh? :D
By jdp
#191686
that's the 1st bubble rendering I have ever seen... and it looks brilliant! 8)
Neat 8)
I like the droplet at the bottom ... did you use real-flow for that ?
By daros
#191711
Very nice Tom!
make a room full of them Tom!
By Xlars
#191712
he he ... what a wonderful idea. Looks very realistic, also the animations.
Exellent stuff
(I suggest you upload your stuff to a permanent server instead of using RapidShare and the like)
Thank you everybody for the critics and compliments :!:
I'm cooking a high res version with a better interference pattern and a detailed environment.
Jeremy: Thanks, sure it's physically-correct :) I wonder if there are alternate software which can map the thickness of thin film interference.
Thomas: Thanks, the droplet is completely hand-modeled and hand-framed. :)
David: Thanks, I'm planning to create different setups with these bubbles. ;)
Xlars: Thanks, I will surely place them on a permanent source when I'm done with these..hehe
