By dlytleb
#327229
I have been using Rhino and Maxwell together for a while now..., but thought I would play with sketch up a bit. I downloaded the the new plug in, but end up with a corrupt MXS file when I export. I am still using MW 1.7, is this the problem? Is there somewhere I can find the older version of the plug-in?
#327233
You have to use a 1.7.x-era plugin to write files for Maxwell 1.7.x -- the file's not corrupt, it's just that Maxwell 1.7 can't read it. If you contact the Next Limit sales desk with your customer info, they'll send you a link where you can download the older plugin you need to use.
