[img]
creasia wrote:A great way to troubleshoot this is to use the export parts of your scene using the "selected only" option into an mxs. You can then import the objects separately into studio and I believe that they will retain their location.
yup, thats exactly what i did for my last project.. Actually I had different items on differents layers, (Train on one layer, Trusses on another and so on) and hid them respectively and exported them seperately into mxs files then opened a Maxwell Studio and imported them individually. This came ofter i tried to export the entire scene at once... it exported for about 7 hours and gave me a runtime error at the very end. (Drove me nuts). Heres a movie of the project... (not sure how to post images... sorry
http://www.youtube.com/watch?v=8iZ5ydpuCg0
as for the tracks which was just too much geometry i was fortuate to export just one set and then use instance to copy the remaining 2 which worked out perfectly. Cant wait for that update though that implements instances in SU tho. In any event, Try that im almost positive it should work.
as far a it being a material problem... well thats a whole new beast on its own. It happened to me a couple of months ago when i was trying to re-adjust my workflow to add maxwell materials in SU... crashed on export with the materials but exported fine when i removed them. After that I never applied materials in SU. i just use colors as placeholders and rename the colors to what i want them to be in maxwell so they can be easily accessible. [/img]
