- Sat Jan 16, 2016 6:04 pm
#389935
When I hit render in 3ds max, scene is exported to temp.mxs and automatically opened in maxwell renderer which indicate rendering process - that's correct, everything render correctly.
But when I export it to mxs format and open in maxwell studio , then after hit the render there I see that spectral file for my IES maxwell emitters cannot be found.
As you can see there is incorrect IES lobe
correct one should look like this:
Icon to browse files correctly point to good location
I perform copy of file to better named folder structure
Opening file with maxwell renderer has also same issue.
Material is converted from maxwell emiter object in 3ds max
I struggling with this and I have no idea.
Code: Select all
When I want to see preview in material editor in maxwell studio - same happen. ERROR: - Spectral file not found ( (null) ) in Material "MxLight028_oltarz"
ERROR: - Data preprocess failed. Render cannot continue
[16/January/2016 16:28:08] Ending render process..
ERROR: - Render Failed As you can see there is incorrect IES lobe
Code: Select all
I also rename it to better name and nothing helped, still the same issue.
C:\Users\Tom>cp "E:\Grafika3D\campoints\MODULAR\IES\MODULAR IES09_2nd Ed_all products\H2A.IES\MOD_9X365052+93360025_54W.IES" C:\Temp
C:\Users\Tom>ls "C:\Temp\MOD_9X365052+93360025_54W.IES"
C:\Temp\MOD_9X365052+93360025_54W.IESCode: Select all
Of course I also opened scene which is saved in *\AppData\Local\Temp location after hitting button in 3ds max but same issue again.mv C:\Temp\MOD_9X365052+93360025_54W.IES C:\Temp\MOD54W.IESOpening file with maxwell renderer has also same issue.
- By Matteo Villa
