By lalllall
#388674
Hi
Im kind of new to Maxwell and maybe im doing something wrong but
I have a problem with the network monitor not updating when im rendering
over the network. The network manager has the correct informations and
the mxis are in the output folder but when i look at the monitor everything
seems stuck.
Below are 2 pictures, the render is clearly at fram 14-18 but the monitors says
its stuck at fram 9 -12
Manager:Image
Monitor: Image
By dk2079
#388677
have you tried closing & reopening of the monitor?
it happens to me, not often. but sometimes the monitor looses connection to the manager or for some other reason stops updating.
usually when I close & reopen things are displaying fine again.(the manager actually runs the whole render process once the job is sent; you can also open several monitors on different computers)
By dk2079
#388680
alright, as long as the manager is alive it is fine.
you might want to have a closer look on the (default)ports that are being used. there must be a reason for why the monitor looses connection. could also be network/switch overload, packet collisions, firewalls,...
Oooohhhhhoooooooo!!!!! This is exciting. Thanks F[…]
Rhinoceros 6 support
I just installed the new maxwell_rhino_v4.2.6.3_WI[…]
Good day! We have just released a new version of […]
Hi there, after a texture tag has been assigned to[…]
