- Sun Aug 17, 2014 5:22 pm
#382335
I create a new Material using any Material Assistant in the Maxwell Editor and save as mxm. When I drag the material into the SWx plugin I get an empty material with the name "Material" instead of the name used.
There is no issue if I switch the material to advanced in the Maxwell Editor before adding it to SWx.
There is no issue if I edit an existing material using the Material Assistant in the Maxwell Editor, leave it as an Assistant material, and then add it to SWx.
There is no issue if I create the material in the SWx plugin, save as mxm, then edit the material using the Material Assistant tool in the Maxwell Editor.
It appears to only be an issue if I create a new material using the Material Assistant in the Maxwell Editor.
- Ian
- Ian
