- Wed Jan 22, 2014 5:49 pm
#377026
Hi Marton,
something in the plug in is really odd with sun /sky .
If I add a maxwell environment with a type of physical sky , the directional light(when set as phys sun in modo) does not actually become a maxwell sun .When it is exported into studio it is still a directional light and sun is disabled under the environment settings .If you enable the sun and disable the directional light the sun is in a completely different position.
Now if I delete the added maxwell environment and change the modo environment to a 701 physical sky , the directional light does become a maxwell sun. But i have now lost control in the plugin of the maxwell sky to alter turbidity etc as this just shows environment type physical sky where the ibl dialog is.Also no control over the sun other than using modo controls .
So in the first way I don't have a maxwell sun , and the second way I have no control of the maxwell sky.
It's been a while since I have used the maxwell sun/sky but I don't seem to remember it being like this?
- By Andreas Hopf
