#369323
It seems it doesn't happen with global bump, but it does with the BSDF bump and instanced object. It should be easy to reproduce, I've just made a new scene that shows it.
This happens with bump in the BSDF (Instance on the left, original object on the right):
I found also a strange behaviour if I put the bump in global and BSDF at the same time:
The scene:
http://www.ftella.com/links/mirrored%20 ... 20bump.max
#369336
Hello Fernando,
Glad to see you.
Sadly I can not reproduce your fail.
Here I have one object and its instance, with a bump map applied to the Global Bump, and as you can see, there is no difference between them.
Am I missing something?
Cheers
Dario Lanza
#369339
Hola Darío,
Mirrored instance? I've noticed if "Use 3dmax instances" is unticked it doesn't happen but it does if ticked; so probably it's only about 3dsmax plugin. I remember Mihnea saying that option sometimes breaks things.
The strange behaviour about using the same map in both global bump and BSDF bump still happens without using 3dsmax instances.
