- Fri Jun 07, 2013 12:18 pm
#368385
Hi.
I am having trouble embedding the multilights in to the EXR output image when i'm rendering animation.
It works when i'm rendering single frame but as soon as i'm turning on animation it stops embedding.
The setup and scene is 100% identical. The only difference is i unchecked single: under the common parameters in the render settings and check range:0 to 0 (just to render 1 frame)
How come this gives 2 different results when it comes to embedding?
the MXI that i also output is identical in both single and animation rendering, containing all the multilights.
is there a mxcl flag i can type inn, to force a embed?
here is a recording of the output files while the animation frame is rendering.
https://vimeo.com/67876158
pass: embed
The 3 top files is the single frame render.
the 3 bottoms are the frame rendered in "range" mode
you can see the size difference on the exr, and at some point it is a similar but right in the end it collapses down. I assume thats when the multilight gets removed from the exr or something.
Cheers.
pass: embed
Cheers.
- By Andreas Hopf
