- Fri Aug 06, 2010 7:52 pm
#328356
Hi!
I am using render layers from maya, could you check the the file name prefix option is supported in the last version? I using the maya command line for maxwell render. The issue is in the -l flag, this render the correct layer but write the image in the masterlayer directory, where it should write in the correct render layers directory.
Thanks.
Uploaded with ImageShack.us
Thanks.
Jorge Medina Alix
VFX TD / 3DFluids Consultancy
Tech RF Blog: RF Wisdom
Personal works (WIP): Liquid Entropy
- By Jochen Haug
