By Richard
#295198
Though not the only time this has occured.
I've Imported a tree in 3ds format from xfrog, everytime time I select all the branches, trunk etc and try to merge - studio crashes.
Windows Vista Ult (SP1) 64bit , dual core 2.2ghz, 2 gb ram.
Studio 1.7.1 64bit
How many triangles in the objects you are trying to merge? With only 2 mb RAM, I suspect you are running out. Vista 64 is a memory hog while even just at idle. Mine reads over 1 GB used at idle...
By Richard
#295201
Bubbaloo wrote:How many triangles in the objects you are trying to merge? With only 2 mb RAM, I suspect you are running out. Vista 64 is a memory hog while even just at idle. Mine reads over 1 GB used at idle...
Yeah you probably have hit the issue there mate! I figured that may have been the issue!
By Richard
#295204
Mind you I think even desipte the memory shortage a complete crash is a bit of a drastic way to punish. Maybe an error report - "Action can not be completed"!
By bejack
#295249
I have the same issue with imported data... seems to be a problem with objects whose normals are "not correct"...
try to check this and flip normals. then it mostly worked for me.
