By m-Que
#292308
Tried to use displacement along with clipmap.
Used the same map for displacement and clipmap both:
Result:
Any ideas what went wrong? :?
By tokiop
#292313
you can try to use texture filtering, it helped me a bit in such case.. Or you'll have to make the clipmap's circle a bit wider (if you want to see the sides)..
By m-Que
#292407
Found a problem:
There was some grey ring left from selection in PS. As a result Maxwell was trying to connect height values on a very small spot. You can see the ring on the bottom of the render.
Sorry for that. :oops:
Thanks for advice, tokiop
Anyway, turns out that displacement/clip combination is very sensitive and tricky stuff.
