- Wed Sep 10, 2008 2:30 am
#279981
I have a small (3 part) assembly that I am trying to render. The assembly has 4 SW lights -- 3 spot and 1 point. The lights are all less than 2 m in distance from a part that is approx .5 m in size. I export to Studio just to double check on everything. All of the emitters appear to be correct in Studio. When I start the render, everything seems fine. The Multilight panel appears OK and the render itself appear OK. However, when I set the "environment" light to 0, the 3 spot and 1 point light do not light the scene. I have tried setting the Multilight sliders to 10000, I have changed to emitter material so that emits 10000 watts. Nothing seems to make a difference. I have used this same technique many times in the past lighting a concrete material against a black background without problem, but I'm using reflective metals for this particular part. The problem does not appear to be insufficient ISO or Shutter.
I know that the general approach is to create "emitter" panels, but I've resisted this approach so that everything is "stock SolidWorks". Any insights or suggestions would be most appreciated.
Ken
Ken
- By Mark Bell
- By Edward Leibnitz
