- Thu Feb 21, 2008 3:48 pm
#261904
I own Vray and Maxwell for Rhino. At the moment, daily I use Vray for Rhino and I love it. The speed is great and 90% of my projects couldn't be done without this speed.
I short tested Brazil some weeks befor, but I found no way to get the needed results. OK, it was a short test, but I feel, the usage is more difficult than of Vray. For example if I like to use HDRI environments at VfR, than I go to "Environment", but I found no way at Brazil for Rhino to set HDRIs.
Also often I have seen Brazil images with an ambient occlusion look, that I don't like. I'm not sure why, maybe the most user use AO.
Also, a big advantage of Vray is the light cache method, that I use allways. It allow to get a fast preview of the complete image ala Maxwell and is be used to speed up the next calculations like Irradiance Map and Reflections.
At the asgvis forum are some starterkits from me with hints. Maybe this helps to get a start. Also, the ASGvis tutorial section should be very interesting, for example for creation of materials.
Rhino3D and more - 3D visualisation for designers and architects ... my gallery ... Freelance. ... www.simulacrum.de
