By zapalamon
#245804
I posted this on the general topic and no one replyed maybe i will have better lucks here.
Can someone point me in the right direction when creating uv maps in maya.
I created simple three plane diecut and i wish to have the projection map on the whole polygon and not each individual polygon plane.
What am I doing wrong?
Thank you in advance.
By KRZ
#245813
just select all your planes the same time and make a planar projektion -> done
By cali3d
#245835
also, in planar projection options, try the different axis if the UV dont look as expected. Yoour UV seems to be projected top down (Y axis)
By zapalamon
#245906
Thanks guys. That helped out but i am still new to the UV idea, is there anything else on the net or here on the forums that would give me additional tips on UV editing.
Thank you
