Hi guys,
I'm working on this new project/job, it's going to be a one on one functional replica of Deckard's Blaster,
The blaster was actually made from two weapons, the first is the Steyr Mannlicher .222 model SL receiver and was used for the top part, the second was a Charter Arms .44 Special Bulldog revolver
Especially the grip and other organic parts will be a challenge in Rhino, So I'll be doing lots of lofting ;)
For the more complicated parts I will use Rhino 4,
Here is a very first render of the bulldog part:
And here a photo of the actual blaster:
That handle looks like a piece of cake for Rhino (it thrives on that stuff). I can see a couple of two rail sweeps, a few trims, and a blendSrf (a couple of times)... just looking at it.
Indeed, good one Thomas, I was thinking lofting but this is even better 8)
Nico, this is looking really promising so far.
Can you explain the Rhino process to produce your model so far?
I would have poly modeled all the pieces, but this 'I can see a couple of two rail sweeps, a few trims, and a blendSrf (a couple of times)...' system seems as though it would save me some time.
Cheers,
Tim Ellis wrote:... but this 'I can see a couple of two rail sweeps, a few trims, and a blendSrf (a couple of times)...' system seems as though it would save me some time.
Not sure about saving time; since you need to build some experience to see the process ahead of time (and it maybe a jump to move from mesh modeling to nurbs; thinking of everything as hollow sheet metal bent and welded)
Here it is a fairly simple shape:
-Starts with some guides to do a 2 rail sweep for the upper and lower surface
-Some trim and then a blend
-Then some more trim and a networkSrf for the finger bumps
Hi Tim, Thanks!
As you can see only Thomas can explain it this clear! :D :D
Thomas you are really a master in making brief and clear tutorials like this!! 8)
Cheers :)
Thank you Thomas, for the explanation.
I'll have a play round with the Rhino demo when I get a free hour or two.
Cheers,
