By MetinSeven_com
#10478
I think that a few new default values might be better:
Maxwell camera: a very common fStop versus shutterspeed value is 5.6 and 1/30.
Standard Watt value for emitter material: 2000 W. 5000 is an uncommonly high light strength and I think it's better to adjust your fStop and/or shutterspeed to adjust the amount of light in your scene. On top of this the high emitter strength will induce sharp edged DOF where objects are positioned in front of the emitter.
Cheers,
Metin
to NL team:
yeah also put the caustics on for us :) i think you are putting them off because of not much having high noise at first sight for the customers... haha.. is that a marketing reason? if yes, then it's not important, we can turn it on every time but if no, why not turning them on and getting them on the same tab as in maya...
By MetinSeven_com
#10557
Good point. I'm always turning on caustics, otherwise it's not unbiased anymore. :)
Cheers,
Metin
