You need to convert it to geometry and remove the Hair flag from the Effects list. Hope that helps.
By JTB
#111213
Adrian is right, but still I have some memory problems or something similar because if I try to use hair as grass on a hill and transform it to geometry, sometimes even MAX crashes or if this doesn't happen MXST can't render. ( I am going to make some more tests because hair as grass is totally realistic.
By Xlars
#116430
1. Convert to geometry (from inside the Hair and Fur modifier)
2. Turn of the Hair and Fur modifier
3. Turn of Hair and Fur render effect
4. Apply a Maxwell material to the hair mesh object
5. Render :-)
By jjgraphics
#116901
I had same problem with max 7.5, but I used same procedure write by Xlars, and you can see result in Topic "Problem with rendering".
Ciao
Gianluca
