By doc
#99622
hi,
by installing deinstalling installing deinstalling....... of the different versions i`ve no reinstalled beta version. but the renderer produces again lots of black dots. i think with correct geometrie and axxis this was a solved bug.
am i having the wrong pluign? isnt 0.6b the latest edition???
thx
By rendertaxi
#99624
hi doc,
yes, the black dots.. they were still there with the beta and the last plugin (i don´t know now because i´m not in my office, but i think it was called 06c, get the july edition from the download page).
i´ve experienced that the black dots even appeared with "correct" geometry.
the only thing i can recommend you is to try to optimize your model in cinema by aligning normals, optimizing button and un-triangulating.
and do that back and forth! as sometimes a geometry needs to be un-triangulated before it can be properly optimized...
i went back to beta as well and am having the same problems...
cheers, alex
By doc
#99626
ive checked the geometrie with higher effort than it took to modell the scene. its horrible.
in the dl area there is only the latest plugin - the onliest i have on my hd is version 0,6b.
can i use the new plugin????????
thx for help.
By jsls
#99733
You cannot use the new plugin with the beta render, I was confused about this too, on the download site there are 2 C4D plugs and the older one says it is for Mac's but it works on both platforms. So far I have only been able to render anything with the beta verion. CineMaxwell 0.6c is the latest "working" version.
By doc
#99751
thx
