- Mon Jan 14, 2013 4:31 am
#364193
Fair enough, there are quite a few parameters in that window.
Next Limit Team
Great! Thanks for sharing JD!JDHill wrote:However, if you're comfortable with the idea of using something that might be superseded in the future, here is a small Ruby script that will put "Save Grass Preset" and "Load Grass Preset" items in your Plugins menu (unzip and put the Ruby file in your Plugins directory). Provided you have a group selected, those menu items will be enabled, and you can use them to, well, save & load Grass settings to & from files. Here's a link to download the file.
Sorry, but the engine does not support this.GRouslan wrote:Wish render layers affect fire engine, to setup scene with only direct light, same for cinema 4d.
+1valerostudio wrote:Thanks JD for the ruby. You are one of the best plugin developers I have ever come in contact with.
