By arch4d
#95351
Hi all, good to have a Plugin,
but when i´m trying to render my beta cinema4d files through the new plugin and RC3, it says very often "invalid normal value".
what does it mean ?
with the beta plugin everything went fine on that scenes.
By rendertaxi
#95405
i got the same error.. :( what´s happening?
By arch4d
#95406
don´t know what this is.
it appears not with every scene, and if i click constantly about 20 times "yes", i get my render too. :roll:
By rendertaxi
#95408
my plugin just tells me:"MXS could not be created".. hmm, i was so positive about the plugin! :?
By greg3000
#95412
I get the error as well, invalid normals
By janosch1234
#95414
same for me.
no render from C4D. :cry:
By arch4d
#95417
rendertaxi: did you delete every cinema material with a map in it ?
then it says to me:
map couldn´t be created,
ahhh, and i had the same problem: mxs couldn´t be written.
this is cause maxwell doesn´t create an output folder during installation.
create one in the next limit/maxwell folder, and it should work
By rendertaxi
#95425
arch4d, thanks a lot, that was the mistake:
i needed to create the folder "output" in the maxwell folder.
"..\maxwell\output\" is where cinemaxwell tries to save the mxs.
alex
By Rochr
#95428
Got the "invalid normal value" error as well. Although hysterical clicking on the yes-button doesn´t work here.
CTRL-ALT-DELETE does however... :roll:
And it took them 5 months to come up with this...
By arch4d
#95429
btw, hope we´ll see that great results known from the beta version from you again with this RC.
I admired your work a lot!!!
By janosch1234
#95438
Many thanks from me too, arch4d.
Another install bug from NL. but with an easy workaround.
P.S.: RenderTaxi, next year i want to meet you at the Katschhof!
We have to render at least one Glühwein ;)
(hab da studiert)
By rendertaxi
#95801
the problem appeared because i didn´t have the beta installed on that machine. if you install over your beta folder, the output folder remains -> nor error appears.
anyway i had no problems installing the newer version over the old one (without deinstalling).
@arch4d: thank you, we will try our best! :) just other projects keep us busy, but i hope soon i find time again.
@janosch: what are you doing in spain then? did you study architecture? ... anyway, rendering glühwein is very hard.. is there a material preset in the RC?
alex
By janosch1234
#95813
renders quality is still very far from beta, but now that there is a working c4d plugin again, i can hope too.
@rendertaxi: I studied civil engeneering in AC.
and Spain.... because of my girlfriend :roll:
I guess whe have to wait until RC100 to have some alcoholic Mat presets :)
