By jjs
#93035
Bizarre
Last night I installed the RC and SW plugin on my laptop which is a virgin machine with not previous contact with Maxwell, and all went well after I added to the environment path. Placed my license file and located it in the Help Menu and all was fine.
I have just loaded on RC and SW plugin on my main machine after uninstalling the previous maxwell installations.
The RC works as far as i can tell and using the Help , I located the new license file
But the SW plugin does not work - It flashes up that the license is invalid. :shock:
How do I get the SW plugin to accept the new license file as so create an mxs file that I can test. The RC does not accept my old mxs files.
I had a feeling I was getting an easy ride :D up to now.
Juan - do you have any clues.
TTFN
Jonathan
By jjs
#93043
ARGGGGHHHHH
I knew it could only get worse.
Now SW just crashes out when I hit the render button in SW plugin.
There must be a hangover from the previous install knocking about - nowonder people got totally pissed off over the weekend .
This brings back all the bad memories of the SW upgrades that SW used to put out a couple of years ago - SW seem to have improved but I still have my Voodoo dolls and JuJu charms ready when upgrading - I 'll have to use them for Maxwell now. Curses.
If anyone has a clue then can they let me know - in the meen time I'll uninstall Maxwell , run a regcleaner and see if I have any luck.
TTFN
Jonathan
By jjs
#93057
Good news
I knew my original Nigerian Voodoo dolls would work - My computer is petrified when I get them out as it knows that non - compliance could lead to a horrible fall from the window.
Uninstalled Maxwell - ran ccleaner and then reinstaled it all and it worked in both RC and Sw.
Juan - your off the hook :D -
TTFN
Jonathan
By John Layne
#93400
Glad this is working for some one! :D
I gave up and went back to the Beta, do you know what REG Keys your CC cleaner deleted?
By jjs
#93422
John Layne wrote:Glad this is working for some one! :D
I'm not selective - I just delete them all :roll: so sorry, I can't be specific.
Anything which had a wiff of maxwell was toast !!
When re-installing I got some dialogue box half way throughthe Rc install about looking for a *.msi file - I just cancelled and pressed on - it claimed Maxwell studio was installed fine at the end.
I then opened RC and went to help and selected the location of the license file.
I next extracted the SW plugin to the Next Limit folder (not the maxwell folder inside Next Limit)
Next I opened SW and using Open > *.dll file type I selected the SW plugin. The I opened a SW assembly and all worked .
Have you another machine to try installing the RC on.
TTFN
Jonathan
Next I opened SW and then u
