#92899
I am attempting to use the form Z plug-in with the new RC version.
I have successfully navigated the issues with the two .fzr files in the plug-ins directory. I have also successfuly managed to load the .dat liscence information.
The issue I am currently facing is when attempting to launch a rendering from Z by pressing the 'render scene' button. I get the following message:
'windows cannot find the mxcl.exe. Make sure you typed the name correctly, and try again. To search for a file, click the start button, and then click search.'
I have reproduced the problem on two machines (one operating windows 2000 and the other XP). I have checked, and the mxcl.exe file is in C:\program\Next Limit\Maxwell\mxcl.
I have attempted to reinstall the software a number of times but no luck.
Does anyone else have this problem? Any ideas how it might be solved?
By j-luc daureil
#93432
I'm not sure this is a good solution, but if you displace the mxcl.exe from C:\program\Next Limit\Maxwell\mxcl
to
(the mxcl.exe is directly under the Maxwell directory in the beta version)
so the rendering windows is launched. :wink:
But there are some difficulties after that... :(
I hope Juan can correct this path in Maxwellz...
I don't know a way to customize this.
May i missed something
Jean-Luc
