By John Layne
#79662
Hi
I have tried to install using Alien on Linspire with no sucess. I'm a total newbie with Linux and am trying to set up a mini render farm.
Any chance some one from NL could give me a step by step on how to get the plugin woring with an easy linux like Linspire or Ubunto.
By Brett Morgan
#79737
John, not sure what package management linspire uses, OK just checked and it seems debian based :D
to install alien (if your sources.list is configured properly) either use synapse package manager in the applications menu(not sure if its there) or use this command:
sudo apt-get install alien
then change dirs to the location of the rpm and type
sudo alien -c packagename.rpm
then you'll have your debian package, then
sudo dpkg -i nextlimitpackagename.deb
then setup your env variables
thats how i did it, and after that you'll be banging your head against the wall because the documentation on installing under linux is pretty non existant, let alone any sort of trouble shooting guide :roll:
Hope this helps some
Brett
By Brett Morgan
#80469
OK another error to figure out:
/usr/NextLimit/Maxwell/bin/mxcl.bin: error while loading shared libraries: libqt -mt.so.3: cannot open shared object file: No such file or directory
fixed that by installing the libarary DUH :D
sudo apt-get install libqt3-mt
command line works now, wasnt getting this error last night though, seems very odd!!
Brett
