- Tue Nov 08, 2005 12:23 pm
#77529
Hi!
I just got my maxwell plug in for Form Z.
I wanted to try it out and so I used a model that I had just rendered with FormZ.
After applying Maxwell materials, I tried rendering and the first two times or so I saw the line: Render failed:-( in Maxwell.
Afterwards, it would crash when I press the render button.
Now I removed layer by layer and tried rendering. I noticed that when the desks (which incidentally is the only shader with a color map) are removed, it starts to render.
Do you know what's causing this or what I am doing wrong?
Macintosh G5-2Ghz, 2MB ram.
