By Maya69
#75867
you can place plug in in maya folder
with your instalation you have help file
you must parametre a global varibale environement (windows systeme)
a+
By zosso
#75993
* Uncompress the fileMayall_071.zip in c:\.
* You need to setup several enviroment variables, in order to do it:
o go to: Start -> Control Panel -> System
o Into the System dialogue look into the Advanced Tab, Click on Enviroment Variables.
o If you a re installing the Plug-In for all the users use System Varibales, if you are installing only your user you can use User Variables too.
* Setup the next variables:
o MAYA_PLUG_IN_PATH = c:\mayall
o MAYA_SCRIPT_PATH = c:\mayall
o XBMLANGPATH = c:\mayall
o MAYALL_ROOT = c:\mayall
* The Maxwell install program must set you enviroment variable MAXWELL_ROOT to the Maxwell install dir, check it. If it doen's exists create your own MAXWELL_ROOT variable pointing to your Maxwell install dir, for example: if Maxwell isinstalled in c:\maxwell, set the enviroment variable to this path.
* Launch Maya and go to: Windows -> Settings/Preferences -> Plug-In Manager
* Go to c:/mayall folder and select mayall_maya60.mll for Maya 6.0 or mayall_maya65.mll for Maya 6.5 .
* Click on Load and Auto Load if you want that Mayall will be loaded every time Maya is launched.
* If you click on the Info button on the right tou can see the Mayall version.
* Enjoy Maxwell!
* ADVANCED: if you want to install Mayall in other location different than c:\mayall, you only need to substitute the c:\mayall path used before by your new mayall installation path.
