By Brett Morgan
#68229
convert the rpm to a debian package with alien, have to do the same to install maya
alien -c mayall-0.9.1-1.i386.rpm
good luck
Brett
By Brett Morgan
#70395
hmm whats the error you're getting? I wonder why a lot of packages go with rpm too, you could just right click and extract the packages i think and move them manually.
Cheers
Brett
By Brett Morgan
#78896
alien converted the rpm to deb format for me so far, still I cant get the plugin to initialize. :roll:
Brett
PS: OK after some stuffing around and adding the required lines to .bash_profile and .profile maya said it couldnt load maxwell because the maxwell root wasnt configured, so i added:
MAXWELL_ROOT=/usr/NextLimit/Maxwell
to my maya.env file and all is well
:P
By Brett Morgan
#79223
Lee does maxwell work for you in command line? There is basically no help in the pdf manual or the mayall docs that help to trouble shoot a linux installation :roll:
Cheers
Brett
