By iker
#66968
Try to correct your scales, by default Maya works in cms.
...you can also change your F/Stop and ShutterSpeed
If the problem persist, share your scene here :wink:
By Maya69
#67064
maxwell use camera physical
if your object size (example bottle) in real life is 30 cm height
you can't size in your scene bottle with 3 cm height
you must respect size object !!!!!
a+
