- Thu Sep 15, 2005 11:01 am
#61523
The Geometry Extraction that happends when you press "Render Scene" is quite speedy compared to other products that interface with SolidWorks. But it still takes a significant amount of time.
When you're playing around with material parameters and just let the render run for a couple of minutes each time to see the effect of a parameter change, this becomes significant.
In this scenario the model never changes.
Would it be possible to use the geometry data from last rendering if the model hasn't changed? Or if thats hard, have a manual option to not run a new geometry extraction?
/j
/j
- By Matteo Villa
