By true
#57217
I know this has been compare before...but since I rendered them, I might just show them here...
I know I did the lighting extremely badly in maxwell.... but what i use is phyiscal sky, sun and due to too dark in the interior, i add a flash light on top of camera 2cm x 2cm
If anyone now how to improve the one in maxwell, please give advise.. :?
vray 1 hr 45 min, original 800x600
maxwell 14hrs 15 level, neat image touch up, original 1200x900
By def4d
#57218
could you share the Max file so everyone could tweak it?
By true
#57220
i dont mind sharing it, but i don't know how to upload....anywhere I can upload?
Yes, the Vray image is better.
It would be nice if you uploaded the file so that others can give it a try in Maxwell. If it is up to 50 MB you can use http://www.rapidshare.de/
(Try zipping it... or use 7zip compression www.7zip.org)
By Renato Lemus
#57254
I personally like both images, but I think there's something wrong with the lighting setup in the maxwell image. Maybe you should use dielectrics in the curtains.The vray one has some artifacts in the top of the windows, big white splotches.
By true
#57313
Thanks for the comments and concern. :)
The vray scene is using very low setting, that's why you can see the wrong lighting effect on top of the curtain. It took 1hr45min
If in high setting, it took about 4hrs. (I might upload it later, if any of you want)
I will try to upload the max file tonight.
By Jun In Gi
#57318
good lighting true.
i aslo want to say vray looks better.
IMO maybe this scene was more familiar with vray.
By Micha
#57329
... the vray looks better
... the maxwell have a problem with the contrast
... but the maxwell glass is great and the vray glass is no glass
... a better setup could help for the Maxwell (blur on the ground, low burn value [0.1] and low gamma [1.5], less sss for the flower, ...)
By vkiuru
#57330
mverta wrote:Yes, the vray scene looks better than a poorly set-up Maxwell scene. Call Guiness.
_Mike
My thoughts exactly.
By true
#57357
:? so that means we can't just hit the render button in maxwell ?...... :P
anyway, if anyone want to try to beat the vray one, feel free to download.
http://rapidshare.de/files/4313336/uplo ... w.zip.html
Well if you want to make a comparison between renders, at the very least have the same lighting. The Vray one has light coming in from the other room, in Maxwell it's completely dark.
If the vray one was done with light panels at the windows then the maxwell one should be the same. When vray will have the physical sky they said they put in, then we can compare that.
Hi Fernando, Thanks for posting this - much appre[…]
MAXWELL STUDIO CRASH - MEMORY LEAK
Hello everybody, I still looking for the reason M[…]
