By jakegoat
#56543
A straight re-render with the original settings and double the res...
Thanks to andronikos for the render here which had the specular changed at Tom's suggestion down: http://www.maxwellrender.com/forum/view ... t=1600_SSS
I took receipt of a new G5 and needed something to test it out - this is the exact same as the first post: http://www.maxwellrender.com/forum/view ... scattering
I am aware that candles aren't that shiny. I like to think of them as plastic wrapped ;) And now the stats. This was rendered on one single 2.7GHz proc, niced into low priority for (drum roll):
[521h 6m 55s] of [60h 0m 0s] , current sampling level : 22.04 -
Heh heh.
By jakegoat
#56550
Yes, only the candle light. Each one is a dipyramid (8 sides in total) as the maxwell renders can get a little hairy(er) with complicated emitters. Remind me to tell you about the beautiful poly flames that I generated from Maya fluids... A little too expensive so far.
Thanks for the kind words.
By chaad
#56557
verry long time...like my modest picture. i remember me "povray" in 1990 when i make simple picture for 7 days. Courage fuyons.
By Micha
#56588
Wonderful mood, very peaceful. :shock:
Let us meditate. :wink:
Thank you jakegoat :D
