By Neil Evans
#4567
Hi
I am trying to run off an image and I keep getting this error message:-
== Render settings ==
resolution: 320 x 240
maximum desired time: 0h 1m 0s
threads: 6
quality: low
target sampling level: 25
>> Starting Render
>> Start Voxelization...
Voxelization progress: 100%
>> End Voxelization...
[0h 0m 20s] of [0h 1m 0s] , current sampling level : 2 QImage::smoothScale: Imag
e is a null image
[0h 0m 27s] of [0h 1m 0s] , current sampling level : 6 QImage::smoothScale: Imag
e is a null image
[0h 1m 0s] of [0h 1m 0s] , current sampling level : 9 QImage::smoothScale: Image
is a null image
SUCCESS: Render successfull
Close this window or the frame buffer to End Session...
The render preview is blank at the end.
Any ideas would be greatfully appreciated.
By tlass
#4584
Hi Neil,
strange result...
Would you like to share your scene... then i could
testrender it myself...
cheers
Torsten
By Neil Evans
#4589
Torsten
I think I found out what it was, there were some maya shaders that Maxwell didn't like. Once I changed them all the MXshaders it rendered fine.
Cheers
Neil
By Brett Morgan
#6239
OK I have had the same error message twice in the last couple of days, thought it might have been some mental ray nodes leftover from old scene files, but I made a scene from scratch, and I'm getting the error message, anyone have any ideas, or the same problem?
Brett
edit: after further investigation it seems it renders only with a resolution of 320x240, change it any higher and the error message appears.
maya 6 scene file:
http://www.mypage.tsn.cc/algorhythm/errorMessage.rar
