By blukarma
#55117
is it possible include all the funcnion in one application and not in 3 applications (monitor, server, manager)?
maybe one application with a tab and 3 windows with on off option for activate or not the server or manager or monitor.
tnx
By RedRaven
#55124
i second that - an all in one net render interface would be very good.
By j_man
#55203
I tell you what though, the server and manager should be run as a service and not as apps. That would probably make everyone happy.
Josh.
By blukarma
#55206
sure but they can be run also on the same machine or two in the same machine.
with an option (able or disable) in the panel you can cotroll the netrender with only one window
By animated
#55702
sorry, but in my opinion merging the server - manager is not a good idea, it creates confusion when you are usign several machines ... leave it the way backburn works ... :wink:
did you tried luxCore?
