By bader
#54760
your options are
1- the film ISO type you can choos 150. 200 - 250~400 << i did that it work
2-also play with shutter speed and the fstop. thats work also
both works. think of it like real cam
By siliconbauhaus
#54762
Is that glass in that wall? I'm sure that this is a known problem with glass and sunlight so try turning the glass off and see what that does.
It also looks like you need to adjust your time and or model as the sun appears to be coming in the wrong place for you to get light into the room
By bader
#54767
filem in real life are 50/100 / 150 / 200 /400
that one of the options to get more light to the film . 400 for night
-time and model also as silicon said
By rivoli
#54770
hindus, you're using quite an old version. you may want to upgrade to the latest beta.
btw
hindus wrote: you mean rotate the room ?
no, sunlight is not getting into your room just because you didn't turn it on. just check "use sunlight".
By Duncan
#54859
Hindus, you should download the latest release.
Also check out the manual that came with Maxwell it will explain F/stops and shutter speeds and ISO.
cheers
By Atak
#55257
where do you download the latest upgrade
By rivoli
#55259
Atak wrote: where do you download the latest upgrade
if you bought maxwell at the same link they sent you by email and where you downloaded the previous versions.
