By j_man
#50274
I'm getting crashes with coop rendering (someone has posted this in the bug reports) when the files are being linked together.
As I understand, each computer renders an image and then they are composited at the end. Is this right?
Two Q's:
-If it is then how can I open the image that one computer renders (where can I find it!)
-Why is this better than me rendering it manually on different computers and then compositing it myself? Sounds like it is safer in the event of a crash!
J.
By j_man
#50324
Thanks Adam!
You should have specified an output location in your .mxc file or export plugin.
Of course I did ;> but when I look into that directory I only see one image. At the moment all of the mxi files are in the network drive I specified in the manager setup.
Apparently M~R is using a lot more than basic screen pixels to produce the combined results. This was quite clear when I did a coop render of a diamond; the individual results showed the stone as quite dark and reddish in color, while the converged stone was much lighter and greenish in tone--as it would have been had I rendered longer on a single machine.
I would believe this also! I'm just wondering if it might not be more versatile if I can adjust how they're merged. Not to mention that if it crashes I still have the individual renders. otherwise I've lost it all!
BTW, I'm getting pretty good results with coop rendering, it's just that it I go home tonight and the link job fails...
[/quote]
By j_man
#50334
You'd think there would be a way to restart the linking the process if it failed the first time, but if there I haven't found it.
something for the future then!
thanks again.
J.
